No fire to plugs
No fire to plugs
99 Silverado with 4.3 , 5 speed
Backed up in driveway wouldn't start back. First thought fuel pump but you can hear it when you turn on switch. Also, sprayed starter fluid in carb and no start no hit. Checked and no fire to plugs. Previously had bad modual so I replaced it again. Still not fire. I had vehicle for fours years and figured wouldn't hurt to change plugs, plug wires and distributor cap and rotor but still no fire. I am getting fire from coil to distributor but none at plugs. Check engine light comes on when you turn on key.no RPM registering. So I replaced the crank sensor thinking that was it but still no power at plugs.
I think that is about it. I have a multi meter but not schooled in its use. Yes it cranks but want hit at all.
Help appreciated.
Help appreciated.
Just saw answer about neutral safety switch. Not back to vehicle but mine is a 5 speed manual would it have one?
Still going to check firing order and then take new distributor cap back off and check
neutral safety/clutch switches would stop the vehicle from cranking not kill spark.
You say you have a check engine light and no rpm showing? What code? I'm betting theres a crank sensor or timing issue.
Ok, disconnected distributor cap and visually inspected it (new) but maybe. No visible issues. Reconfirmed firing order and plug wires to be sure correct. Still no fire at plugs.
There are no codes showing. Crank sensor already replaced.
you say you replaced the crank sensor ? well if you don't get those crank sensors lined up right it will ruin it as soon as you crank the engine ! the way I always did it was I marked around the old one before taking it off, that way I could put the new one back in the same spot ! hmm ! spark from the coil to the distributor but no spark to the plugs ? sounds like the rotor button or another thing it could be is the distributor shaft is not turning when you crank the engine ! take the cap off and have someone crank the engine to see if the shaft is turning !
