Break goes to the floor/no leaks
There must be a leak somewhere if the fluid is gone after pumping the pedal. If you can't see any leaks under the van then the master cylinder is leaking into the brake booster and you might see the leak under the hood.
Maybe the slave cylinder seals leaking, but you won't know until you take the drum off, you'll probably have to replace the shoes too, best to do both sides whilst you're about it for even breaking.
William Kisselstein
Express & G-Series Vans
November 24th, 2019 10:34 PM
Dawgmobile II
March 6th, 2011 8:39 PM
