Astro 1985-2005
Platform: M-Body
99 Astro - Drove to the store, now won't start.
Old March 31st, 2012, 11:38 PM
  #11
EinST's Avatar
I think the Astro has maxi fuses for high current junctions and mini fuses for the rest. They all should have holes on top on either side of the stamped amperage number for inserting a sharp probe or a paper clips held by alligator clip attachment. In a pinch, the voltage can be measured by inserting the probe into the socket with the fuse removed (be careful not to spread the blade socket). At least one side should show a voltage in that case.
Old April 3rd, 2012, 1:35 PM
  #12
ANGELZ2457's Avatar
I had the same problem, i changed the ignition coil and sprayed my intake with starting fluid, after it did not start with the new coil and it turned on right away. I have an astro 2000 and when it would rain it would usually not turn on till two days later.
Old April 9th, 2012, 8:26 AM
  #13
Jacqu LeCouq's Avatar
Hey guys - took it to the shop this past Friday, and it ended up being the starter. Just for anyone who was curious. Thanks for the help!
Old April 9th, 2012, 5:45 PM
  #14
EinST's Avatar
Oh, okay, thanks for the update.
Old February 10th, 2016, 10:24 AM
  #15
Josh Middleton's Avatar
Default 04 Astro won't start
I just moved for a warm climate where the van has been its whole life to scold climate. As soon as the temp dropped below freezing it won't start but if kept in a warm parking garage it starts and runs fine. I have had the fuel pump, plugs, plug wires, rotor, battery, and distributor cap replaced. Still same issue. When it lived in wet climate I never had theses issues only in the cold. I've tried the oil pressure test but I haven't tried the spark test but the mechanic assured me that it's spark is good. I'm at my wits end and at the point of getting rid of it but it's a good vehicle and don't want to. Please any tips. The other day I parked it at work and it did the the no start thing. We pushed it into the sun and popped the hood for about 30 mins, it struggled for a sec but then started. Thought I should add that. Please help thx!
Sabertooth
Silverado & Fullsize Pick-ups
11
December 13th, 2009 11:16 PM
Sabertooth
November 30th, 2009 3:38 PM
FamilyOf5
June 11th, 2008 2:56 PM
Saby7
January 28th, 2007 3:04 AM
Quick Reply: 99 Astro - Drove to the store, now won't start.
