2000 Chevy starting/running problem
My 2000 Astro is having trouble starting. It takes several tries to start, and then when I put in reverse it stalls. Restart it and it runs pretty good until I need some speed when it feels like it loses power and then goes again. It is not throwing any codes, and the fuel pump is going on when the key is turned. The van has 107,000 miles and the last time the fuel/air filter were changed was 25,000 miles ago.
I also noticed this morning what looked like oil leaking from right beside the rear passenger tire. However I just had an oil change 2 days ago, and all my problems started prior to having it done.
Last year it had a simular problem, which turned out to be the cap and wires having condensation. At that time the problem was throwing a code and would work itself out as soon as the van drove for awhile. So this problem is a little different.
The only other problem that I have been having with the van is when I put the AC/Heat on the compressor ticks like crazy, and bogs down the engine. The ticking gets faster as you step on the gas. It can't get out of it's own way upon acceleration.
Can anyone help??
Can anyone help??
It is recommended to change the fuel filter every 20k miles. The stock fuel pumps last about 100k miles, cheap replacements much less. The pumps usually don't just die, they get weak. I've driven a few thousand miles on a pump that couldn't create enough pressure to start the van, started the van with starter fluid. Change the fuel filter and check the fuel pressure.
Oil by the rear tire sounds like an axle seal going bad, pull the wheel and drum to verify.
Ticking compressor, could be a bad bearing in the unit.
Starting Problem
My Chev Astro Van has some starting problems, you can turn key all the dash board lights come on, but the engine will not start. You turn tthe key several times and nothing happens. Then you wait a couple minutes it will start. It dont do it all the time, just when you least expect it. I had the starter check out and it is fine. I talk to a lock smith and he think it might have something to do with the anti-lock system.
New User
Awaiting E-mail Confirmation
this is interesting, my van has the abs system lights that come on periodically, and then may stay on for days. and now My van is giving me starting problems. Is it possible for the abs to keep you from getting started?
BuyOuts
Express & G-Series Vans
November 10th, 2009 8:16 AM
sandy0225
Silverado & Fullsize Pick-ups
February 17th, 2009 3:55 PM
