Just dies out for no reason
Guys, please help me to figure out and thank you in advance for your help.
Ihave Chevy Astro 2001. I replaced its radiator but I didn't have a red colored coolant specified for GMC but instead I used a green ordinary coolant.
The ff day, it just died out for no reason. Does it (coolant) really the reason?
I noticed that when I stick ignition key, the temp and oil monitors goes up to 12 oclock position but when with the engine running it goes back to where it should be....
I am not convinced it its really the coolant, please help me.
Thanks
Jimmy
Thanks
Jimmy
I am not convinced it its really the coolant, please help me.??/
Thanks
Jimmy
Thanks
Jimmy
Steve, Thank you for the possibilities.
I called my mechanic and he found out that there was a sparks leaked in the coil, specifically on the high tension cable leading to the distributor. He was able to fixed it and it didn't die out so far. Still under observation and planning to buy new coil....
It was normal before we changed its radiator except the ABS/brake monitor lights but it was hard to start and still the same.. I think it is the coil that is about to expire? Thank you so much and God bless.
augr
February 28th, 2008 1:28 AM
