Rear Doors latch jammed: 1991 Astro
My 91 Astro back door lock was jammed, I can not open it, and the door handle was broken too!
I attempted to open the interior plastic to release two internal rods of which linked to lock. But I still can not open it.
Any suggestions to open the door?
Greatly appreciated!
Since you have access to the rods, make sure they are still connected. They shouldn't be able to flop around. One of the rods needs to be in the up position to unlock the door and the other needs to be pressed down on to unlatch the door.
Thanks
Yes, they were still attched and worked. One to the lock, when I turn the key it moves up and down, and the other connected to the door handle, however, the door handle is broken. When I push it down, I can feel that the door handle was leveraged by this rod.
I did not know that the lock rod and the latch rod should be oppsite to open the door. I will make a test, and get back to you!
Thanks very much!!
Ching
Thanks very much!!
Ching
G-Force
July 20th, 2009 3:18 PM
d1nonly34
November 21st, 2008 5:17 PM
Rivernut
December 20th, 2007 10:54 AM
