astro 97 van starting problem
Does Not start some days,
Unless I spray quick start on Air Filter area.
Changed Fuel Filter back in Nov/08,
Basically had no problem in winter time.
HAd changed Fuel Pump less than 3 years and have about 40,000 Km after that
current milage 191,000 KMs only
Could it be Fuel Injector Pressure Regulator?
EWhere it is loacted and how to test it ?
Pl help ASAP>
Thanks
ALKA
Pl help ASAP>
Thanks
ALKA
Does it turn over and not start? My does then when the distributor get wet on misty days. I have to take the doghouse of and spray ignition dry spary on it.
