Chevrolet Avalanche
Platform: GMT 805 & 900
08 Avalanche cruise control intermittent
Old January 14th, 2015, 10:47 AM
Axle314's Avatar
Default 08 Avalanche cruise control intermittent
Cruise will engage about 50% of the time when I push the set button and once or twice while on cruise it stopped and green indicator was gone from dash.?????
Old January 15th, 2015, 7:57 AM
Axle314's Avatar
You mean to tell me no one has had cruise issues in an avalanche ? If so and you had repaired what was the common issue here. Thanks
Old February 2nd, 2015, 3:16 PM
z28summit's Avatar
Your brake switch is starting to go. If it happens again, try making an braking application. Should work after that. If it gets bad, its a $30 part GM. Its located straight up above the brake pedal under the dash
Old February 3rd, 2015, 6:38 PM
Axle314's Avatar
Thanks summit !
Old June 18th, 2015, 12:12 PM
jezitzma's Avatar
Mine went out, bought one off of amazon and it took maybe 30 minutes to replace. Found a YouTube video before I started. It helped a lot. Works great.
crosskeystv
November 17th, 2022 6:38 AM
Relayer56
Avalanche
18
March 29th, 2021 10:43 AM
e-roc559
Silverado & Fullsize Pick-ups
December 13th, 2013 11:58 PM
asgraber
Avalanche
August 11th, 2010 9:02 AM
kbridge234
September 4th, 2008 10:03 AM
Quick Reply: 08 Avalanche cruise control intermittent
