Chevrolet Avalanche
Platform: GMT 805 & 900
2005 Avalanche P0449 Issue
Old August 25th, 2015, 10:48 AM
ramccombs's Avatar
Default 2005 Avalanche P0449 Issue
I have a 2005 Chevy Avalanche with a check engine light. Checking the code it indicates P0449.
I have replaced the Evaporative Emission Canister Vent Solenoid Valve twice. First time I drove about 1700 miles before the check engine light came back on. Second time the check engine light did not go out. I reset it with my analyzer, but a few days later the check engine light was back on with code P0449.
I have having another issue with the Avalanche. I don't know if the problem is related, but when I go to start the vehicle if I just stick the key in the ignition and turn the key it will just crank and not start. If I attempt to start it again it usually fires right up. If I put the key in the ignition and turn it (but don't crank it) and let it set for about 15-30 seconds the vehicle will normally start right up.
I have tried to do as much research as possible, but have "hit a wall."
I was also wondering if the fuel vapor charcoal canister could be the problem. If so, where is this located? What is the part number? How difficult is it to replace?
I really appreciate any assistance.
Respectfully
Robert
U.S. Navy Disabled Veteran
07tahoe
April 29th, 2016 10:55 PM
Darren DeLoe
Avalanche
December 19th, 2015 1:42 PM
jvelasco23
Uplander
16
October 29th, 2013 8:21 PM
frazercom
Equinox
November 26th, 2009 11:47 AM
j0nblazeish
Uplander
September 25th, 2009 6:42 PM
Quick Reply: 2005 Avalanche P0449 Issue
