Continues cranking after releasing the key
I have 2008 avalanche the problem is it continues to crank even after releasing the key. Replaced the starter and relay and it does the same thing. Any help would be greatly appreciated!
I would next check the ignition switch. Remove the relay and see if it still does it. If it continues to do it, then it is not the switch, If it continues then there is a short after the relay.
The following 3 users liked this post by oldchevy:
2004Suburban (November 29th, 2023),
Dcp1234rick@aol.com (October 21st, 2021),
tech2 (October 21st, 2021)
Randall Kogelman
Express & G-Series Vans
14
October 6th, 2016 12:09 PM
