Chevrolet Avalanche
Platform: GMT 805 & 900
5.3l 't' vin 2002 avalanche knock sensor
Old February 27th, 2017, 12:20 PM
ddollar's Avatar
Default 5.3l 't' vin 2002 avalanche knock sensor
Question about sensor two hole socket. So there are two sensors, the one closest to the throttle body is number one and I see a lot about water causing damage and tricks to minimize water damage with sensor one and if I pour water in the hole it would fill up like a glass.
So my question is on the sensor two hole. I can see right through the bottom around the edges so I pour in water its going to go right down. I see something like the cam down there. Is that normal for the bottom of sensor two hole? or is something missing around the bottom of the hole like a seal?
Old February 27th, 2017, 3:42 PM
ddollar's Avatar
Default Solved myself
I found it is a valley pan gasket kit that includes the grommets; I'm missing one on the sensor two port. Got it from summit racing. So if your grommets gone bad or leaking this is the thing you need.
