Chevrolet Avalanche
Platform: GMT 805 & 900
Old July 22nd, 2015, 12:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
blower motor not working
Old October 23rd, 2013, 2:33 PM
New User
Awaiting E-mail Confirmation
milehighmark's Avatar
Unhappy blower motor not working
The blower motor on my 07 Avalanche just quit working? When I adjust the fan speed on the dual climate system the display shows I'm changing speeds but nothing is coming out. so what is the best educated guess the switch or the blower motor resistor? or something totally different??? it's just great that now that the weather is turning cold here now the heater quits... also not sure but isn't there a TSB or recall on this problem
Old October 24th, 2013, 2:27 AM
Jeff Collision's Avatar
Commonly the blower circuits gets power supply through a fuse to relay then fuse to motor, if your getting voltage to the motor then motor doesn't work at any speed then the trouble may be a stuck or bad motor. If you verify the motor is ok then the trouble is either with the fuse or relay or switch or the resistor pack.
Old October 24th, 2013, 8:43 AM
New User
thanks for the reply I have not been able to check the motor yet but the fuses are fine
Old October 25th, 2013, 9:23 AM
New User
OK,let me approach this problem a different way,I have a 07 avalanche LTZ it has dual climate & auto climate control, the fuses are good,the fan does not work at all,if there is power to the blower motor what would be the next logical cause, I've read blower motor resistor and blower motor control module is there a difference, which one would my truck have? any help help would be really appreciated, or should I just give up and go to the dealer.
Old October 25th, 2013, 9:59 AM
jtho53's Avatar
Exclamation Blower motor not working
I recently had a 2005 Impala with the same problem. I tapped the motor and it ran but had stuck brushes. Resister assemblies seldom go bad.
Replace the motor.
John
Old October 26th, 2013, 8:43 AM
jtho53's Avatar
Take a meter and check for power to the motor. If you have power and varied fan voltages at the plug to the motor then all is well in the dash and replace the motor.
Let me know how you do.
John
Old October 31st, 2013, 6:32 AM
New User
just a note to finish this this off, had my local shop look at my problem it was the blower motor,200.00 parts/labor all is well
chevywilly
November 26th, 2014 6:05 PM
TehTaylor
Silverado & Fullsize Pick-ups
May 30th, 2013 6:26 PM
mathblaster
November 2nd, 2009 5:33 AM
gofer
Express & G-Series Vans
October 20th, 2009 7:53 PM
rsaz
September 15th, 2008 10:41 PM
Quick Reply: blower motor not working
