Factory Nav, Rear Back-up Camera and GMX550 Install
I don't post here often but I do a lot of lurking...so I figured this was as good of time as any to speak up and show you guys the project I completed yesterday.
I own a bike review website (Bike198.com), so I have a bike rack on the back of my truck 24/7 which renders the backup sensors useless. Since the back of the Avalanche is so big with all of the plastic, you can not see the bike rack folded up at all. I had a feeling I was "that guy" in the parking lot that you always see with about 3 extra feet behind him backing up, so I decided to bite the bullet and install a back-up camera. Mine actually came with the factory 6 disc w/o nav, so I had to install the following...
Factory Nav Head Unit
Nav Antenna
Rear Backup Camera (small CCD off eBay)
GMX550 Lockpick (I had the wiring for factory backup, but I wanted to use the different camera and get the iPhone/iPad integration)
Anyways...the entire install went pretty easily and everything is up and running.
The hardest part was bringing myself to actually drill into the plastic on the tailgate. Measured about 80 times to drill once. Looking at the back of the truck, you barely even notice the flush mount camera is there and it provides the perfect viewpoint of the rack empty and loaded up with bikes.
Luckily, I have a really great GM dealer close by that worked with me for about an hour on trying different code setups on the head unit until we got the combo that worked perfectly. That was a huge help.
Nav Antenna
looks like a smooth install and great upgrade. Did your oem have Bose & steering wheel contl? Did the lock pick include a VSS adapter wire for the NAV. I'm looking to do a similar upgrade, just cant find the right unit & adapters to make it all work. I have a 2007, CD/ BOSE/ REAR ENT DVD/ NO NAV. Would you know what GM part # the unit is? ending in 66 or 67 or other. Thx
Hate to bring back a thread from the dead but I need help finding the right Nav head unit for my 08 LTZ (no rear entertainment but I have Bose). I want to do the same back up camera and lock pick setup in mine but want the DVD capabilities with the lock pick integration. I learned there are 2 versions of the nav so I need to know which part numbers I should look for or physical features that will help identify the one I need. Thanks
chassispro
May 5th, 2014 9:11 PM
Y&R
Silverado & Fullsize Pick-ups
August 6th, 2009 5:59 PM
biglg
16
February 19th, 2009 10:22 PM
