Chevrolet Avalanche
Platform: GMT 805 & 900
Front End shutter/vibration 02 avalanche 1500 4wd
Old July 10th, 2014, 9:01 PM
Fireman7606's Avatar
Exclamation Front End shutter/vibration 02 avalanche 1500 4wd
I have a vibration in the front end of my truck. I have replaced both wheel bearing since I've had problems with them before. I have also replaced all the shocks with the same kind, and also replaced the driver side cv axel and still doing the same thing. I also had a front end alignment. When I put it in Auto 4wd I notice a shutter when you turn at a slow speed, ( Example.. Moving around in the yard) I have owned this truck since new and just noticed it this past winter. There is a slight vibration when traveling at road speeds between 50-70 MPH. When coming to a stop it sounds like the CV joint in the axel is bad and there is a slight clicking noise. Has anyone else has this issue? It's very annoying!
Old July 11th, 2014, 10:48 PM
sledge.impy's Avatar
Are you still on the original/same tires or are you on new/different tread tires(like off-road type)?
Old July 12th, 2014, 6:35 AM
I habe a different set of tires on it. It dose not feel like a tire vibration, my steering wheel isnt Vibrating you can just feel it overall. As for the shutter it only does it in auto four-wheel-drive, and It doesn't matter if you're in grass or pavement.
Old October 12th, 2014, 11:20 AM
mobiletec's Avatar
check u-joints on front drive shaft
Whatnext
Silverado & Fullsize Pick-ups
August 16th, 2013 8:37 AM
Last
Cobalt
July 9th, 2012 7:01 PM
chezandy
January 8th, 2012 3:03 PM
barbie42058
Express & G-Series Vans
June 23rd, 2010 9:25 PM
smoothice
February 22nd, 2007 2:14 PM
Quick Reply: Front End shutter/vibration 02 avalanche 1500 4wd
