Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1995 beretta cooling fan problem
Old October 5th, 2008, 12:13 PM
Tosha0516's Avatar
Default 1995 beretta cooling fan problem
The fan will come on only when the ac is turned on.I can turn the ac off and the fan will continue to run for awhile. Once it shuts off the car begins to run hot and the ac has to be turned on again for the fan to run. The relays have been checked they are working.I don't know what the problem could be, any help would be appreciated.
Old October 5th, 2008, 2:33 PM
jackyshaikh's Avatar
Default RE: 1995 beretta cooling fan problem
It could be ECT (ENGINE COOLANT TEMPERATURE ) Sensor just unplugged the connector of sensor put fused jumper or a resistor and see if it spins.If it does replace the sensor.
Old October 5th, 2008, 8:51 PM
Tosha0516's Avatar
Thanks so much.Could you tell me where the ect sensor is located?
Old October 6th, 2008, 11:50 AM
Tosha0516's Avatar
as soon as the ect sensor is unplugged the fan will begin to work.
Old October 7th, 2008, 2:47 PM
Do you mean when you unplugged the ECT Sensor connector the cooling fan started working without puting fused jumper in conector pins?
Old October 8th, 2008, 1:38 PM
Tosha0516's Avatar
Yes, thats exactly what happened. Sorry it took so long to get back.
Old October 9th, 2008, 4:28 PM
Never mind.so did you replace ECT sensor?
Old October 9th, 2008, 7:54 PM
Tosha0516's Avatar
Yes, that fixed it.Thanks for your help.
Old April 2nd, 2010, 4:10 PM
heisabud's Avatar
Default A toggle switch
I was having the same problem , I somply installed a off / on switch in the center console. A year or so later I also replaced the two sensors in the thermostat houseing and put in a cooler thermostat.
tom p
November 19th, 2014 10:26 AM
bass
February 8th, 2014 8:20 PM
htopball
May 6th, 2010 6:00 PM
kaneless
January 15th, 2008 12:27 PM
xswinnyx
May 13th, 2006 1:01 PM
Quick Reply: 1995 beretta cooling fan problem
