Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
91 corsica fuel problelms
Old August 4th, 2007, 5:00 PM
richrd's Avatar
Default 91 corsica fuel problelms
my 91 3.1 has been haunted for a while now. it has 110,000 miles. in the past it would sometimes loose power like it was starving for fuel then eventually it got worse and more often until the fuel pump quit.
I replaced the fuel pump and things were better for a while until I forgot that the fuel guage read high and ran out of gas..
the car now will not run.
whenI turn the key fuel pressure will go to about 15 lbs then back to 0. Turn the key off then on again and the pressure will go to 30 - 40 and again bleed back down.
turn the key and it starts, stumbles, and pressure goes to 43 at which point the motor stalls and the fuel pressure goes back to 0
did I cook the new pump or does this sound like a pressure regulator problem.
Thanks
Rich
Old August 27th, 2007, 8:22 PM
TheRedMouse's Avatar
Default RE: 91 corsica fuel problelms
check the fuel pressure regulator, the diaphram is most likely broken and or leaking. very common.
Evgeny
December 23rd, 2012 1:59 PM
hunter10220
Silverado & Fullsize Pick-ups
May 18th, 2011 8:37 PM
MOOSE513
September 4th, 2007 9:30 PM
showin57
March 13th, 2005 1:36 PM
Quick Reply: 91 corsica fuel problelms
