Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Coolant leak 1995 Lumina
Old August 21st, 2012, 10:44 AM
RolloTomassi's Avatar
Default Coolant leak 1995 Lumina
I've got a coolant leak near the timing chain on my 1995 Chevy Lumina. If I take this to a repair shop, what will they do? If I take the DIY route, what kind of coolant repair products can I use to fix it myself?
Bear in mind, I do not have a lot of money and I'm a novice. I can spend maybe $30-40 to fix this car on my own before taking it to a professional, thanks
Old August 21st, 2012, 12:00 PM
If it helps, I changed the water pump, lower and upper radiator hoses and radiator cap within the past 12 months
Old August 21st, 2012, 5:00 PM
bump!
Old October 14th, 2012, 5:54 PM
92chevycorsicalt's Avatar
Is it coming from around the water pump?
Old October 15th, 2012, 8:14 AM
The leak has actually stopped for now, weird lol
Old October 17th, 2012, 1:09 AM
Banned
harry5's Avatar
I had just replace the radiator but it again causing some problems.
Old December 23rd, 2012, 2:32 PM
GHOSTOWLGRID's Avatar
Possible leaking points:
Timing cover front or rear sides.
Lower intake manifold gasket which is right above timing cover.
Water pump which is on the timing cover housing.
Or one of the hoses above the water pump.
Old January 14th, 2017, 11:34 PM
MCRC007's Avatar
Could be as easy as this little hose right here
Old July 29th, 2017, 9:50 AM
shawnabecker's Avatar
bump!
dlaroche
October 29th, 2014 7:17 PM
Warbucks79
11
September 11th, 2013 2:10 AM
Warbucks79
April 16th, 2013 11:24 PM
Jessicalynn927
July 1st, 2010 6:34 PM
95wt
May 30th, 2008 3:07 PM
Quick Reply: Coolant leak 1995 Lumina
