I need to move my 95 Corsica without a key
I've never done this, but with an automatic transmission - you might be able to remove the transmission shift cable at the transmission and then move the lever on the transmission itself putting it in neutral?
You'd probably have to move the lever back to the correct position to put the cable back on.
You should also try moving the lever with the cable on - that might work too.
dberladyn
Express & G-Series Vans
30
June 24th, 2015 10:28 PM
O7SuperSport
January 17th, 2015 12:45 PM
jzimm
Silverado & Fullsize Pick-ups
December 22nd, 2012 10:13 PM
sixpack_sid
July 30th, 2009 8:56 PM
