2014 camaro AC failed...
Hey guys. So here's the story. Me and my friend share a 2014 chevy camaro 1LT, 6spd manual, 3.6 V6. Apparently a few days ago he said the AC stopped working in the car. He checked the freon, it's full. But when the max AC is turned on, there is no cold air coming out of the car. He took it to electrical fix but it ended up that the shop told him to visit AC fix, but the AC fix tells him to go back to electrical. We believe it is the compressor problem. Any ideas? Please help, we are in Texas and it is over 90 degree daily...it is a pain to drive a black car under 90 degree sun...
I'd check for battery voltage on the connector, and in your case hope it isn't there. It's either an electrical problem such as the connector, or high pressure switch is open. The system uses a high pressure switch as a safety. I am not sure with a 2014 it also has a low side protection.
