2016 Camaro
Platform: F-Body & Zeta.
'87 Monte carlo ... Cranks but doesn't fire
Old March 29th, 2017, 7:29 PM
adj_1958's Avatar
Default '87 Monte carlo ... Cranks but doesn't fire
Stock '87 Monte Carlo ... 305 w/Roch Quad ... 70K miles. Cranks but doesn't fire. Fuel comes out the primaries ... Spark at the plugs as I used a spark checker. It draws air (vacuum) as I held my hand over the carb. ECM has no codes except "12" so I assume the ECM is good. Ran great on Monday, went to start it today (Wednesday) and here we are. Any ideas?
Old March 29th, 2017, 7:59 PM
kevinkpk's Avatar
If you have spark, you need to determine how is the spark? 87 would have come with ESC, probably a distributor issue. Code 12 is just key on, and nothing with OBD1
