94 Chevrolet Camaro 5.7L lacks power and misfires
#11
The car has new coil and wires. The dealership that the kid took it to right before I bought it said there was a fuel pressure drop when you hit the gas. They told him they replaced the plug wires, cap and rotor assembly, and fuel filter. I believe that it is truly timing related. The car will not start all the time and when it does the rpm's jump all over the place and it runs like ****. It will turn over and not start but if you wait a minute or two it will fire and it will also diesel on occasion. I want to believe that the dealership did something foolish like not properly seat the rotor assembly but I haven had time to look at it. It pisses me off though because when I test drove the car a month before the purchase it ran decent. So no it is not fixed yet. I realy do not want to trap door the trunk for the fuel pump or drop the tank. If any one has actually fixed the similar issues above let me know. I do not want to replace stuff I don't have to.
#12
It sounds like all the work was done before you bought the car and it was fine?
A dealer tells you what to change and you don't want to do it. and you keep thinking it's something else.
Are the plug wires hooked up correctly or crossed? Are any arc'ing?
#14
At least it should run good for now. How many miles?
