Caster/Camber bolts needed, 85 Caprice
I've a 1985 Chevy Caprice Classic, 305H, 4dr,
Does anyone know where I can get the front upper control arm bolts? The local chevy dealer doesn't even list the part, the salvage yard said the cost would be outrageous, and so far, the alignment shop is trying to find them too. without much luck.
I'm using some grade 10's at the moment which I chiseled some serrations into. Had to hammer them in, but they didn't work right when trying to align.
Any info would be much appreciated!
Competion wheel studs for camber/caster bolts?
Had a thought, would competion wheel lug studs have the right grade for use as control arm bolts? Considering the right size were selected.
tableclocks
Silverado & Fullsize Pick-ups
October 12th, 2007 5:24 PM
