Platform: B-Body
ground issue
Old September 16th, 2016, 5:06 PM
91 caprice's Avatar
Default ground issue
How do i find a ground issue
Old September 18th, 2016, 5:11 PM
kevinkpk's Avatar
Your question is vary vague, please tell what your issue is.
Old September 18th, 2016, 7:21 PM
you measure the voltage drop after the load to the grounding point. power the circuit in question and put your meter lead after the load and the other on the grd point. should have less than 0.2volts reading on your meter.
but yes, post your concern. Hard to help when the problem is not known.
Old September 18th, 2016, 10:18 PM
91 caprice's Avatar
the concerned area is where the speed sensor is located the instrument cluster needle does the dashboard and then cuts out amd kills the car when the senior is hooked up
Old September 19th, 2016, 8:15 AM
clairify
the instrument cluster needle does the dashboard???
...when the "sensor" is hooked up?
Old September 19th, 2016, 8:39 AM
91 caprice's Avatar
When the vechile speed sensor is connected the needle on the dashboard goes from 0-80 it free moves it doesnt move with the actual speed of the car and then it cuts out and dies
Old September 19th, 2016, 3:20 PM
kevinkpk's Avatar
Is the car moving when this happens? Sounds like the speed sensor is at fault since those things are'nt adjustable, they just "fit" in. The other thing to add about grounds, Ohm meter with one side to battery ground, the other to "what area" you are wanting to check. There should be less than .3 ohms, that number will be bigger the further away you are from the battery, but not much.
Old September 19th, 2016, 3:22 PM
kevinkpk's Avatar
One thing if you have an ohm meter, check both pins to ground, it should read either infinity, or a large resistance to ground, make sure the sensor is installed. Also check the sensor, that's both pins. You should have some resistance across the coil of the sensor, I don't know that value, guessing 25-200 ohms.
Last edited by kevinkpk; September 19th, 2016 at 3:23 PM. Reason: Also check the sensor, that's both pins. You should have some resistance across the coil of the sensor, I don't know that val
Old September 19th, 2016, 9:44 PM
91 caprice's Avatar
Yes the car moves 3 feet and then it cuts out and dies i dont know what type of sensor it is but im positive its to a 700r4 transmission i would like to replace the sensor and see if that helps
Old September 20th, 2016, 12:28 PM
kevinkpk's Avatar
You can google that information, that should send you to it.
