Platform: J-body
2000 cavalier rear door stuck closed
Old May 13th, 2011, 3:16 PM
Mbell's Avatar
Default 2000 cavalier rear door stuck closed
Out Side handle does not work
Inside handle and lock do not work
Took apart door panel from inside, sprayed it down with some lubricant and it made parts move smoother but no go on the latch itself.
I tried prying on a few things but nothing will budge. Anyone have any insight on this issue?
Old July 10th, 2011, 8:12 PM
shepherdspie88's Avatar
I have the same issue... I did find that my door is locked, when I pull the outside handle there is no tension, thus making me think it is locked and when I removed the inside panel I saw that the rods were bent and not working correctly.
How would I go about releasing this so I can unbolt the door. The front side by the hinges is not an issue, I can take those off easily, but I cannot figure out how to either release the lock or how to remove the part where the latch hooks onto...
Any advice would be appreciated...
Old August 1st, 2012, 7:55 AM
Merlin777's Avatar
I have the exact same issue with my 2004 Cavalier.... Google finds LOTs of fold with same issue... Have yet to find ANY solution...
Chevy dealer said they can fix it for $400.... did not say what they would do....
Old August 1st, 2012, 2:34 PM
Segfault's Avatar
If I had such an issue I'd take apart the other door to learn how this lock works.
Burnett 1500
Silverado & Fullsize Pick-ups
April 30th, 2015 3:41 PM
Dawnrazor
Astro
February 5th, 2013 12:39 AM
Hotwires
February 14th, 2012 9:03 AM
97astrovanner
Astro
July 22nd, 2009 12:49 AM
mrb2222
August 22nd, 2006 12:55 AM
Quick Reply: 2000 cavalier rear door stuck closed
