2000 chevy cav 2.2
2000 chevy cav 2.2
I HAVE A 2000 CHEVY CAVALIER 2.2L AUTO. it stalls/cuts out while driving so bad that rpm gauges drops to zero . no check engine light . I've replaced fuel pump, fuel filter, coil packs, plugs wires, knock sensor crank sensor , what else could it be next thing im going to replace is probley fuel injectors
when you say cuts out while driving is it at a certain mph or slowing to stop decelerating from highway, or accelerating at any point. neutral switch on shifter if there still is one, or ignition switch-segfault and I agree sounds electrical now that you replaced all that other stuff already. but alot depends on when the stall occures
