Platform: J-body
2002 Vin: F 2.2 interference or non?
Old January 26th, 2014, 7:03 PM
New User
Awaiting E-mail Confirmation
Eose's Avatar
Default 2002 Vin: F 2.2 interference or non?
As title states, I have a 2.2 Vin: F that recently had the timing guide break. Not sure if it jumped time or not. But if it did are these engines interference or non?
Old January 26th, 2014, 7:44 PM
Welcome to the forum
From everything I could locate it looks to be interference.....
Here it says the L61 engine which in the attached picture shows as VIN F
Hopefully Tech2 will see and respond, he is pretty knowledge on these type questions...
Service Information 2002 Chevrolet Cavalier | Cavalier, Sunfire
Service Manual | Document ID: 1480369
#PI00434A: 2.2 L61 Engine Crank , No Start - kw break broken chain cylinder head knock lubrication no noise nostart nozzle oil timing - (Mar 22, 2004)
Subject: 2.2 L61 Engine Crank No Start
Models: .
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Engine will crank but not start, also makes noise while cranking. Condition may be caused by a broken timing chain.
Recommendation/Instructions:
Install service kit p/n 12578218 which includes:
A. A new S-Pin Chain p/n 24461834
B. A constant (no check valve) lubrication nozzle p/n 12577163
C. And drive parts.
Repair after a broken timing chain should include inspection of the cylinder head, the L61 engine is a valve interference engine (not free spinning).
Attached Thumbnails 2002 Vin: F 2.2 interference or non?-2002-vin.jpg
Old January 26th, 2014, 9:32 PM
you right in2pro, they are interference.
At this point is it just rattling bad or a no start?
Old January 26th, 2014, 9:53 PM
New User
Eose's Avatar
The chain guide shattered, (the long straight one.) I believe when that happened the car died And haven't tried to cranked over since. I haven't done any kind of test to check or even really look if it jumped time.
Old January 27th, 2014, 8:45 AM
New User
Eose's Avatar
Also, it's going to be a chain driven water pump right? And I guess while I'm in there I should replace the balance shaft?
Old January 27th, 2014, 7:10 PM
nope and nope.
not on the 2200 engine, ecotec 2.2 yes but they only went in cavs starting 2003
shoveldead
July 11th, 2015 8:42 AM
rainman6969
Equinox
July 30th, 2014 12:46 PM
Jim Welsch
July 2nd, 2012 7:42 AM
Classical Glass
November 14th, 2009 9:05 PM
exuL1B47
February 14th, 2009 10:19 AM
Quick Reply: 2002 Vin: F 2.2 interference or non?
