Platform: J-body
2003 cavalier Cooling fan not coming on
Old July 29th, 2014, 5:51 PM
slinkeril's Avatar
Default 2003 cavalier Cooling fan not coming on
Hello, i have a 2003 Cavalier with the 2.2L Ecotec engine. The cooling fan isn't kicking in when temp is up or when ac is turned on. I have checked the fuse(30amp) its in good condition and I have swapped the blower motor relay with the fan relay to check and make sure the relay was good....blower fan still works but still no cooling fan. I have tried starting the engine with the ECT sensor unplugged and also tried unplugging it while the engine was running, neither turned on the fan, i then unplugged the fan, and put a meter to it to see if there was power going to the fan, and repeated the previous procedure ... but there was no voltage at the connector for the fan. I am not sure where to go from here, is there a method to see if the connector wires are bad? or perhaps if the computer is bad? any idea on which pins on the ECM i can ground to possibly force the fan to turn on and see if my computer is bad?
Old July 29th, 2014, 10:03 PM
sledge.impy's Avatar
Wire the fan directly to the battery. Or use a paper clip/wire to bypass the relay??
My 2002 cavalier fan motor burned out, I had to replace it at 85,000 miles or something.
Heat Seeker WS6
September 23rd, 2013 9:12 AM
Mike San
December 29th, 2012 10:48 AM
mattro
August 13th, 2011 10:07 AM
jbronc88
March 22nd, 2007 11:14 AM
xswinnyx
May 13th, 2006 1:01 PM
Quick Reply: 2003 cavalier Cooling fan not coming on
