2004 Cavalier Base oil pan replacement
My kids cavalier needs a new oil pan. I have located several but none seem to have a gasket available. Is it possible that a gasket is not used with this years oil pan and only sealant is? Is there a specific kind of sealant to use if that is the route to go? thanks!
Excellent! Thank you very much. thought I was losing my mind that i couldn't find a gasket. I normally have my kids buy books for their vehicles but don't have one yet for this car. Is this a pretty straight forward repair. No dropping engine or removing rear end to access anything?!
Awesome thanks
for the help. Got the pan off and saw that it appears the sealant was applied to the engine mating surface not the pan. It does'nt look like it was on the flat surface of the pan but just on the inner rim. I tried to mark it on the new pan picture. should i try to get it in the same place or just on the flat surface of the pan?
