03 Cavalier Headlights
Ok my low beam headlights do not function at all. Parking lights, turn signals and hi-beams work but not low beam. Fuses were checked bulbs were replaced even though I saw no break in the lamp. So what next??? After doing a little research it's possible it could be the dimmer switch. So with that said and me not being automobile saavy where exactly is the switch located? Is it located under the dash on the left side of the steering wheel or is basically the lever that turns on the lights? All the information I have read stated that it's fairly easy to replace, is this correct? If so I don't mind tackling it but first I need to find out where in the car it is and I can't seem to find that anywhere on here. Someone please help.
David_lee1993
November 1st, 2012 11:06 PM
