Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Past Chevrolet Cars > Cavalier
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read Used CarsGarageVendors TSB & Recalls
Search
Welcome to Chevrolet Forum - Chevy Enthusiasts Forums
Platform: J-body
LinkBack Thread Tools
Old 10-13-2009, 06:54 AM
Default 96 Cavalier 2.4 won't crank
I'm a rank newbie on this forum, so forgive me if this has already been answered.
My 96 Cavalier 2.4 automatic suddenly refuses to start, or even crank. The "battery" light came on and stayed on, but it continued to start just fine 3 or 4 times. Now when I turn the key, the fuel pump whines, but the starter solenoid doesn't click and the starter does nothing.
All accessories work fine, including the power windows. The battery shows 11.8v, as does the solenoid. I have checked and tightened all ground cables and battery cables. Both solenoid terminals show continuity. I have traced the ignition circuit from the ignition switch, through the transmission range sensor output, and it all gets full voltage with the key in the start position. But the starter motor positive terminal (connects through the solenoid) gets no juice.
I'm thinking it has to be a failed solenoid, as it's getting good battery voltage, but doesn't so much as click. But the thing that's worrying me is that the battery light came on several starts before, yet continued to start normally. What am I missing?
Thanks for your help.
Register today for free or log-in if already registered to remove this ad!
Tags
1996, 24, 96, 98, battery, cavalier, chevy, crank, crankshaft, diy, engine, gm, light, solenoid, starter, turn, wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
