Platform: J-body
CavalierZ24 2000 Engine start but stops immediately
Old July 6th, 2014, 12:41 PM
Pedro_Zambrano5378's Avatar
Default CavalierZ24 2000 Engine start but stops immediately
I have a car Cavalier Z-24, 2000, has 100,000 mi. I live in Venezuela and bought some parts when I was Miami, because here are not achieved.
I want to take this prestigious forum to raise the issue having my car
The engine was revised, he changed the rubber valves, compression was measured with a result of 170, 180, 170, and 200 PSI, he checked the sensors and all is well. He put new injectors, ignition module, coils and spark plug boots. Also the fuel pump and pressure regulator are recent. The dashboard displays all the messages and then just go out leaving only the battery and checkengine. The scanner does not indicate any code.
The problem with this is that it turns on and three seconds off. I think blocking the fuel pump or injectors, since it sounds like you have no time string.
Excuse me for my English translator google
Old July 7th, 2014, 1:14 PM
I have a car Cavalier Z-24, 2000, it has 100,000 mi, the engine was revised, I changed the rubber valves, compression was measured with a result of 170, 180, 170, and 200 PSI, I checked the sensors and all is well. I put new injectors, ignition module, coils and spark plug boots. Also the fuel pump and pressure regulator are recent. The dashboard displays all the lights and then all just goes off leaving only the battery and checkengine lighted. The scanner does not indicate any code.
The problem with this is that it turns on and three seconds off, I think that it is blocking the fuel pump or injectors, since it sounds like you have no time chain
Can somebody help me please?
Old July 7th, 2014, 2:30 PM
sledge.impy's Avatar
So with no cranking by the starter - the car shuts off after 3 seconds?
Or are you engaging the starter and everything turns off after 3 seconds?
Old July 7th, 2014, 2:33 PM
http://www.google.com/search?q=2000+...osition+sensor
Old July 9th, 2014, 1:50 PM
When I put the car in the starting position, it turns on
Keeping the switch on starting position for 6 seconds, to 3 seconds.
1. The engine turnes off and the crankshaft continues to rotate due to the momentum of the starter up to 6 seconds.
2. The fuel pump and fuel injectors are disabled.
3. There are no explosions in the cylinders.
After the previous time I can return to start the car, but this does not turn on, only the crankshaft rotates and there are no explosions.
In spanish
Cuando paso el swicht de encendido a la posición ON, el carro enciende.
Manteniendo el interruptor en posición de encendido por 6 segundos, a los 3 segundos
1. El motor se apaga y el cigüeñal sigue girando debido al impulso del arranque hasta los 6 segundos.
2. La Bomba de gasolina y los inyectores de gasolina se desactivan,
3. No hay explosiones en los cilindros.
Después del tiempo anterior puedo volver a arrancar el carro (switch a ON), pero este no enciende, solamente el cigüeñal gira y no hay explosiones.
Old July 9th, 2014, 2:21 PM
Thank you for the information.
How can I measure the crankshaft sensor if it is failing?
What values of voltage can I measure in it with a digital tester?
JOUT22
Silverado & Fullsize Pick-ups
March 8th, 2013 3:13 PM
stanman
Camaro
January 7th, 2012 4:12 AM
TheBadger7
Astro
April 7th, 2010 3:33 AM
hbldesign
October 29th, 2008 5:20 PM
mookie
August 23rd, 2007 3:09 PM
Quick Reply: CavalierZ24 2000 Engine start but stops immediately
