Platform: J-body
2003 Cavalier Shaking at high speeds
Old December 12th, 2011, 12:14 PM
bigblue1184's Avatar
Default 2003 Cavalier Shaking at high speeds
I have a 03 Cavalier.
First my car was shaking when i would accelerate up to 60-65mph. I took my car in and had them balance and align my tires and check for bent rim. All checked out fine.
Now when i am driving at highway speed of 60-65 it will start to shake then stop for a while then start shaking again.
If it does do this at lower speeds i am not noticing it. At higher speeds i definitely notice it, but it is not doing it the whole time i am driving at 65. It is really random.
Any suggestions?
Old December 12th, 2011, 1:45 PM
chipmunk's Avatar
it could be a bearing,cv joint, tie rod end , but i say a bad tire put the front on the back[both] see if that helps it can also be a input shaft coming out of the tranny i try the tires first if it keeps on then check all the above
Snuggyworm
July 2nd, 2014 9:59 AM
Brendan Baker
July 29th, 2012 11:46 PM
Fed51
March 19th, 2012 9:45 PM
impala_guy
March 7th, 2009 12:55 PM
cavyone
May 25th, 2007 2:16 PM
Quick Reply: 2003 Cavalier Shaking at high speeds
