Platform: J-body
Need help on a transmission problem!
Old February 8th, 2016, 2:58 PM
Matt Stevens's Avatar
Default Need help on a transmission problem!
I have a 04 Chevrolet Cavailer an it won't kick in to passing gear when you first pull out unless I run it about 4000 rpms for awhile and then it will jerk reel hard and go and after it finally kicks in it and theen it runs fine until I stop and it will do it again. I have changed transmission and vss( vechile speed sensor) and when this started my speedometer stopped working also? Any suggestions would be appreciated.
Old February 8th, 2016, 7:42 PM
cleveland63b's Avatar
does the speedometer work now? have you checked your fluid level?
Old February 8th, 2016, 9:50 PM
ditto
the vss is a very important input to the trans for shift control.
