no day time runners and pass sides light is super dim
i have an 01 cavi and i got no drls and the pass side light is super dim and ive checked every thing i can think of like,the fuses and the bulbs. I cant seem to figure it out if any one knows please let me no. thanks
RE: no day time runners and pass sides light is super dim
ORIGINAL: wally123
i have an 01 cavi and i got no drls... and ive checked every thing i can think of like,the fuses and the bulbs. I cant seem to figure it out if any one knows please let me no. thanks
#2 - Check to see if the high beams work , the DRLs use high lamps at reduced current.
#3 - if these check out it's likely the DRL module
Swap this lamp over to the driver's side and if the problem follows ... it's the lamp.
Don't know if this applies to '01's, but for some reason GM used cheap connectors that will rust in mid 90 models. The connectors are located in the wiring between the headlights. Just start undoing the tape , starting at the left headlight and work towords the middle. I've done a number of these. If this is you problem, just crimp in some new connectors.
HTH
HTH
