Platform: J-body
Passlock Issue? 99 Cavalier Bi-Fuel
Old April 11th, 2013, 7:06 PM
luv2sled's Avatar
Default Passlock Issue? 99 Cavalier Bi-Fuel
Help...99 Cavalier Bi-Fuel will start for about 1 second and then die. This has happened for about a year, but seemed to do it when it was cold. We would wait for a while and try it again and it would start. Now, it will not start. I have tried reading the resistance in the passlock system and putting in resistors to match and bypass the system, but no luck. Starts for 1 second then dies. The dash lights, gauges and odometer have also flashed randomly and sporadic. I have done the relearn process several times with different resistors, but it won't stay running. We do notice a pretty strong natural gas smell after the car shuts down.
I still think it's the Passlock sytem, but the sporadic flashing of the dash lights may indicate a computer problem somewhere. I have owned the car for about 1 1/2 years and shows low miles, 59000, if that is correct as the odometer freaks out sometimes.
Any help would be greatly appreciated!
Old April 11th, 2013, 10:07 PM
tymr287's Avatar
Are you getting any Codes?
Old April 13th, 2013, 6:23 PM
luv2sled's Avatar
Default Codes
Had the codes read today at Autozone and this is what we got: P1215 and P1629.
Any help would be greatly appreciated. Should I start by replacing the ignition switch? Passlock Sensor? ECM? BCM? Would like to bypass the passlock system if it is possible.
Thanks!
jfujinaka
July 27th, 2013 10:21 PM
wafer64
May 17th, 2010 10:12 AM
sweetj24
April 16th, 2010 11:55 AM
Sunshyne276
July 19th, 2008 9:04 AM
Sunshyne276
July 19th, 2008 1:01 AM
Quick Reply: Passlock Issue? 99 Cavalier Bi-Fuel
