Tire Pressure for 2002 Chevy Cav. - Chevrolet Forum - Chevy Enthusiasts Forums
Prezmil2020's Avatar
June 10th, 2008, 8:44 AM   #1
Hello,
Can't read the correct PSI for tires for my 2002 Cavelier (4-door, auto trans.). Anyone know what it is? Thanks.
shawnvw's Avatar
Professional Mechanic
June 10th, 2008, 2:15 PM   #2
RE: Tire Pressure for 2002 Chevy Cav.
ALWAYS fill the tires to what is rated on the tire. NOT what is printed on the tire placard.
Remember the Ford\Firestone incidence?
The correct tire pressure is on the sidewall of the tire, usually in small print near the rim
June 11th, 2008, 7:14 AM   #3
Thanks! I am not known for my car knowledge.
shawnvw's Avatar
June 11th, 2008, 4:15 PM   #4
NP....anymore questions feel free to ask
And wlecome to the forum!
June 20th, 2008, 9:22 PM   #5
Hi all!
I have same question, cause i'm confused.
GMs' (and some mechanics) "recommended inflation pressure" for Cavy02 -30-32 PSI
New BF Goodrich Premier Touring (bought last year) shows max. pressure (with max load) - 44 PSI.
What pressure is correct?
Thanks
July 26th, 2008, 3:55 PM   #6
44 psi. . as stated above, always run tires according to their requirements printed on the tire sidewall.When you run at max pressure your tires will wear evenly and you will get much more life out of the tires!
Also, my experience is most tire shops will actually let the air out of your tires (even if you specifically request they not do this) to 30-35 when they rotate or balance, so check your pressures afterwards and fill them back up to 44.
August 6th, 2008, 11:07 AM   #7
If you can't tell what the tires say then I would recommend 35 PSI. But I agree always go with the tire recommendations
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
