tire rubbing shock
tire rubbing shock
i have a 98 cavalier and the right front tire is rubbing the coil spring seat and i can not figure whats causing it and the tires are stock size and its just started here in the last little bit any help would be great
...loves his pinto I bet. hope it doesn't explode.
for your cav....something is bent or a suspension part is ready to fall out. did you hit anything? Is the steering wheel off-center when you drive? search you tube for how to perform a front end check. Things like wheel bearings, ball joints, control arms.
i put the spare tire on so it wont rub but i did notice the coilspring seat is rusted tru and looks like its being pushed down
also had the wheel bearing changed last week
bpeter3429
Silverado & Fullsize Pick-ups
July 22nd, 2010 9:02 PM
jeffshelton12
January 30th, 2007 7:03 PM
