Help w/ Disassembling Clutch Hydraulic Line
I'm having a lot of trouble disconnecting the clutch hydraulic line from the
clutch release cylinder a.k.a. slave cylinder. It says to push in the release slide, but I seem to only get about a couple millimeters w/ it. Is it stuck? What can I use to lubricate it? I assume only brake fluid. Also, should it be easy enough to pull apart w/o any tools? Thank You.
Mike4207
Silverado & Fullsize Pick-ups
October 17th, 2014 10:16 AM
BSR29
July 13th, 2011 10:07 PM
