weirdest leak ever
weirdest leak ever
I just bought my daughters 05 cavalier after she purchased a new car, I am new to these forums but not new to cars. I have never seen this before.
I backed the car into the drive way to do some maintenance to it (the vehicle is facing 5-10 degrees down hill at this point) and noticed some fluid under the car, I thought is was condensation from the a/c. after several minutes the pool was larger and I checked it out. it was antifreeze. so I checked all over for leaks and could not visibly see anything except that is was dripping from behind the motor somewhere.
I filled the coolant level back up and move the car to a level spot. after two days there is no coolant missing and nothing on the ground.
So I pulled the car into the driveway today and left it facing up hill and again after all day there is no coolant missing or any on the ground.
I am very confused by this why the car only leaked when facing down hill, anyone ever have a leak like this before?
thanks
Mike
thanks
Mike
after a little more research it looks like there is a weep hole in the water pump and when that leaks the seal is shot and it's time for a new pump.
strange that I have almost 100 views on this thread and no answers.
guess I'll need to find a different cavalier forum.
I just joined this forum and read your post. I was going to mention the water pump weep hole, but looks like you figured it out. Hopefully the water pump is something easily changed on Cavaliers.
Good luck
Good luck
SuperTexan
Silverado & Fullsize Pick-ups
June 2nd, 2014 4:36 PM
