Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2005 cobalt ls overheating .
Old November 23rd, 2011, 1:43 PM
slowbalt2005's Avatar
Question 2005 cobalt ls overheating .
hi how are you doing? i am new to this but it seems like a good way to get some help. i am coming home from a 6 month deployment and my car was driven while i was gone at least once a week. i noticed today that my temp was at 215 so i pulled over and shut my car down. i checked the coolant level and it is about a inch above the fill line. so i started my car and the fan never turns on. so i replaced the two relays and i tested the 2 fuses they were good. i tested the fan and it read 12 ohms which is good. and now im not sure where to go from there and i cant aford to take it to the dealership to spend 80 dollars to find out that a 2 dollar sensor is bad. i can not find the location of the fan sensor but i didnt have alot of time to look for it because i had to go to work. also my cobalt is the 2.2l ls.
Old November 23rd, 2011, 3:28 PM
EinST's Avatar
Welcome to the forum. The fuses have little probe holes on top so that the voltage can be measured without their removal. Check:
Voltage levels at the 30A Cooling Fan fuses, both of them
Continuity to ground at the cooling fan, black wire
Also, see if the cooling fan will run with the A/C compressor on.
Old November 23rd, 2011, 4:33 PM
ok i will try that when i get off of work tomorrow, thank you and i will let you know how it goes.
scholls22
July 30th, 2020 2:26 AM
eglaze88
December 14th, 2016 1:52 PM
CStrohbeer
Equinox
January 28th, 2012 9:25 PM
solpushcart
October 5th, 2011 9:39 AM
Cavalier2005
May 6th, 2011 12:38 PM
Quick Reply: 2005 cobalt ls overheating .
