Need help with sway bar bushing bolt
Hi all,
New to this site
I got a pair of new bolts from dealer today. However I am very confused about the black plastic ring over the bolt.
Should I screw the bolt in with that piece of plastic on? I found it impossible to push the ring through the bracket hole...
Thanks for any input
New to this site
I would say that since the old one didn't have it, you don't need it. I did notice that the new bolt is longer than the old one. Will this still fit and tighten up? Also, why did you need new bolts?
I want a new set of bolts b/c the sway bar noise has been there forever, even with new bushings... I worked on the bolts too many times and its kind of rounded off...
burrellp
Silverado & Fullsize Pick-ups
October 23rd, 2014 6:02 PM
RockVegas
August 31st, 2013 5:08 PM
