Intermittent A/C problem
I read through some of the other posts on this issue and it seems like mine may be a little different.
My A/C works great when it works, not low on freon (checked low side only as I no longer have manifold gauges ), does not cycle on and off, my coolant temp and ambient temp seem to be reading fine, however still the A/C sometimes just doesn't work. Clutch doesn't even try to engage when it isn't working and locks right up when it is working.
My thoughts are A/C relay, or pressure switch? Anything else I could be missing?
P.S. I don't think this is related but my cruise control works only about 75% of the time, the key fob works about 95% of the time, the fob controlled trunk button does not work, my front speakers do not work, and the passenger airbag sensor thing is broken.
My 2008 5 speed has intermittent problems with the AC too. When my temperature gage does not give a temperature readout, my AC does not blow cold. When the temperature gauge works, AC blows nice and cold. Defrost same symptoms as AC.
It coded P0128, and so I replaced the temp sending unit, then the thermostat. Still workes sometimes, sometimes not.
Now my tachometer sometimes quits working and the engine misfires, stalled completely once.
Any ideas? I have had my ignition changed out under the recall a few months back.
Wack
Engine Building & Overhauling
January 26th, 2007 6:07 PM
golfhound888
October 4th, 2006 5:37 PM
ffarv
Silverado & Fullsize Pick-ups
April 9th, 2006 1:52 PM
