Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
What is Normal Coolant Temp Range for 2.2L
Old December 16th, 2007, 9:35 AM
pstokes's Avatar
Default What is Normal Coolant Temp Range for 2.2L
What isnormal coolant operating temperature rangefor the Cobalt 2.2L engine?
I recently purchased an '07 Cobalt LT for my son and was driving it in rush-hour traffic. The coolant temperature routinely reached 217-221 deg. F. When I got home, I let it idle in the driveway to see when the electric cooling fan was cycling. Itcycles on at the above temp.until the coolant reaches ~200 deg. F. Is this normal? Seems a bit high to me. Most engine thermostats open between 195-205 Deg. F
It was not a hot day. The air temp was 70 deg. F and I was moving 20-30 mph. Not very severe driving conditions. I then turned on the A/C. Interestingly, it ran cooler (~205 deg. F). I suppose this is due to the second (A/C condenser) cooling fan turning on with the A/C.
I would think that cycling up to 220 F frequently would be detrimental to the engine long-term.
pstokes in H-Town
Old December 23rd, 2007, 9:35 AM
EvansBlue's Avatar
Default RE: What is Normal Coolant Temp Range for 2.2L
No, thats a fairly normal running temp. Late model cars generally run between 190-225 routinely without any damage. Any less than that and you start getting PCM problems.
Old January 5th, 2008, 1:37 AM
brainmuncher's Avatar
Mine runs at 185-190. Yours sounds like it is running a bit hotter than usual.
Old January 13th, 2008, 9:53 AM
BigHog's Avatar
Just got my 08 last week.
So far, with air temps running between 35-50 degrees, she's been running around 195.
Don't think I've seen over 200 yet.
Old July 1st, 2008, 6:58 AM
bigbacon's Avatar
my 06 runs anywhere between 190 and 200
Old July 3rd, 2008, 12:38 PM
wiesem's Avatar
my 05 runs between 185-200 and its a rare 200. so it does seem hot
Old July 7th, 2008, 12:28 PM
Philanderer's Avatar
You live in texas? That's to be expected. Just watch the temp guage and make sure you're not going into the red.
RazzMaTazz
Equinox
March 18th, 2015 7:09 PM
ss2202
February 25th, 2009 7:51 AM
espy59lc
Silverado & Fullsize Pick-ups
January 1st, 2009 1:16 AM
rarchar
August 23rd, 2008 7:31 PM
Red Ron
June 29th, 2008 8:56 PM
Quick Reply: What is Normal Coolant Temp Range for 2.2L
