ac off 2008 colorado
#11
Hello jrs1842,
Were you able to figure out what was causing this issue? As a customer service representative, I'm not able to provide much in the way of do-it-yourself information, but I would be happy to look into this concern for you. Feel free to private message me if you have any lingering questions or concerns.
Jennifer T.
Chevrolet Customer Care
Jennifer T.
#12
Official GM Rep
Please continue to keep us posted, jrs1842. If this continues to be an issue we suggest getting into the dealership, but we'd be here every step of the way if additional assistance was needed. Feel free to reach out via private message if you have further questions.
Amber N.
Amber N.
#13
I have recently started running into the same issue, it goes off and then back on all the time, I have a mechanic that is going to look into it however very strange this is happening to a lot of the same vehicles!!!
#14
I've started experiencing the same problem. AC OFF comes on and temperature gauge stops working. I can only assume the two are related.
The truck is being worked on at a dealership for the second time for the same issue. The first time they assumed it was a battery issue and replaced my battery. Has anyone resolved this?
#15
I have my problem solved
I had the same problem, what i did was to replace the thermostat, it was causing that the temp gauge stopped working and then the AC turned off for system protection, as soon as i replaced that piece, i have had no problems since a year ago approximately. best regards
#16
This just happened to me this past week. I'll take it in to the shop to see if the thermostat thing works. 99085 miles on the truck. One wreck. Auto door locks and driver's power window don't work. (Module in door?) Thanks.
#17
ac of, temperature gauge down
ac off message came on and the coolant gauge is registering cold. I checked fluid and is full, I change thermost, water pump, temperature sensor, the problem still there, some body have the solution?
#18
Not a problem anymore.
My issues stopped when my mechanic swapped out the thermostat. They ended when I traded the truck off.
