ac off 2008 colorado - Page 2 - Chevrolet Forum - Chevy Enthusiasts Forums
jrs1842's Avatar
August 22nd, 2014, 6:46 AM   #11
Posted By: Chevrolet Customer Service Hello jrs1842,
Were you able to figure out what was causing this issue? As a customer service representative, I'm not able to provide much in the way of do-it-yourself information, but I would be happy to look into this concern for you. Feel free to private message me if you have any lingering questions or concerns.
Jennifer T.
Chevrolet Customer Care
Negative. Still got same issue. I can reset my codes and works fine for a day or two then back same thing. It also throws a code for throttle body sensor. Not sure if they related but common sense tells me there not related.
Official GM Rep
Global Headquarters in Detroit, MI
August 22nd, 2014, 5:17 PM   #12
Please continue to keep us posted, jrs1842. If this continues to be an issue we suggest getting into the dealership, but we'd be here every step of the way if additional assistance was needed. Feel free to reach out via private message if you have further questions.
Amber N.
Brianpittens's Avatar
January 15th, 2015, 5:01 PM   #13
I have recently started running into the same issue, it goes off and then back on all the time, I have a mechanic that is going to look into it however very strange this is happening to a lot of the same vehicles!!!
nadeau22's Avatar
January 29th, 2015, 10:26 PM   #14
I've started experiencing the same problem. AC OFF comes on and temperature gauge stops working. I can only assume the two are related.
The truck is being worked on at a dealership for the second time for the same issue. The first time they assumed it was a battery issue and replaced my battery. Has anyone resolved this?
cparra0107's Avatar
January 30th, 2015, 7:43 AM   #15
I have my problem solved
I had the same problem, what i did was to replace the thermostat, it was causing that the temp gauge stopped working and then the AC turned off for system protection, as soon as i replaced that piece, i have had no problems since a year ago approximately. best regards
Kent2008Colorado's Avatar
December 2nd, 2015, 8:41 PM   #16
This just happened to me this past week. I'll take it in to the shop to see if the thermostat thing works. 99085 miles on the truck. One wreck. Auto door locks and driver's power window don't work. (Module in door?) Thanks.
chichibal's Avatar
March 24th, 2016, 11:01 PM   #17
ac of, temperature gauge down
Posted By: monigas Does anybody have the assembly and electrical diagrams for the chevy colorado 2008 ^?
I will appreciate it
thanks in advance
ac off message came on and the coolant gauge is registering cold. I checked fluid and is full, I change thermost, water pump, temperature sensor, the problem still there, some body have the solution?
March 25th, 2016, 6:37 PM   #18
Not a problem anymore.
Posted By: chichibal ac off message came on and the coolant gauge is registering cold. I checked fluid and is full, I change thermost, water pump, temperature sensor, the problem still there, some body have the solution?
My issues stopped when my mechanic swapped out the thermostat. They ended when I traded the truck off.
rcly6270's Avatar
June 14th, 2016, 8:41 AM   #19
Hi, I have the same problem with my 2008 Colorado, (AC Off) where you able to take to the dealership and if so did they find the problem.
rcly6270's Avatar
June 14th, 2016, 8:42 AM   #20
Tags
Sponsors
