Chevrolet Colorado
Platform: GMT 350, GMT 31XX
Steering shaft
Old August 31st, 2010, 6:54 AM
chevy_girl007's Avatar
Default Steering shaft
I have an 05 and noticed a popping sound last summer in my steering section and had the right tie rod and steering shaft replaced. the popping is back and is also noticeable when i brake. I was told by a reputable friend that it was more than likely the steering shaft. I'm just trying to avoid a massive bill. anyone else having this problem? and is this something that is covered under warranty?
Old August 31st, 2010, 7:54 AM
cooter26's Avatar
http://www.fourwheeler.com/techartic...air/index.html
We had the same problem on our 04 Suburban. Basicly its a bad design and all the grease dries up inside. The replacement shafts have been redesigned and it is a fairly easy job to replace it at home. Do a search and you will find some step by step instructions with pictures.
rich_ncal
November 23rd, 2008 9:51 AM
jjallou
September 2nd, 2008 7:54 PM
larryboy58
Silverado & Fullsize Pick-ups
February 5th, 2008 5:49 PM
cas
October 24th, 2007 10:02 AM
bigsid
October 27th, 2006 10:42 AM
Quick Reply: Steering shaft
