2011 Chevy Cruze LS Thermostat (Fan Constantly Running)
#11
Fan running
I'm putting in my second one today!! This seems to be a problem with the Chevy Cruz! I put my first one in August of 2015 and putting a new one in today! Thankfully the part had a 1 year warranty or I would be pissed! This problem should be recalled by GM / Chevy and a new part redesigned to fix this from happening!
Not happy I'm even having to replace this again, free or not!!!
#12
Dame Problem
I bought this car a year ago, because it's suppose to be a dependable car. All of a sudden engine light comes on, cooling fan constantly running. Take it to dealer, and I'm told we need a new thermostat and thermostat housing. $432.00. Check Internet, and it seems to be a very "expensive" common problem for this vehicle. No recall on this?
#13
Fan running all the time
Having the same problem except I do not have a check engine light. The fan will run constantly on high. Only shuts off for a few seconds then is back on. Doesn't matter if AC is on or the defrost. I just had the water pump replaced and coolant tube under power train warranty. Now this problem. With no check engine light I don't know if it's the thermostat or coolant temp sensor. Annoyed
#15
Hello KingDavid73,
We apologize for any trouble you've experienced as a result of this fan concern. Are you planning on having a certified technician take a look at your Cruze? If so, we'd be more than happy to contact the dealership on your behalf and review this in greater detail. If you'd like to move forward in this route, please send us a private message and include your VIN, mileage, contact information, and preferred dealership.
Thank you for your time and enjoy the rest of your day!
Jasmine
Chevrolet Customer Care
Jasmine
Much Thanks
#18
As was mentioned in a previous thread it may be the coolant temperature sensor in the radiator. To check it you need a reader to verify the temperature sensor of the engine, radiator and air intake agree within 1 degree after an extended time parked, say overnight. If anything is skewed the fan will default on
#19
Samanthageorge27
Cruze
October 27th, 2015 8:48 AM
