Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
1977 chevy 350
Old December 15th, 2012, 12:45 PM
Bberry's Avatar
Default 1977 chevy 350
I have a chevy 350 with water in the oil pan. I have removed the intake and found water in one of the ports. Would this be a intake gasket leak of cracked head?[ATTACH]1977 chevy 350-image.jpg[/ATTACH]
Old December 15th, 2012, 12:57 PM
kevinkpk's Avatar
I'd suggest since the manifold is off, clean it up, and check it for cracks.
Old December 15th, 2012, 1:39 PM
old dog's Avatar
Default leak
the motor look's a little bit rough ! if itr is a saver i would pull the head's ,have them maqgnafluxed for crack's check the intake surfaces for trueness . the photo did not look like it was sealing to the intake portion of the cylinder head very good .
Old December 15th, 2012, 1:44 PM
kevinkpk's Avatar
Probably pulled the gasket when he pulled the intake.
Old December 15th, 2012, 3:08 PM
old dog's Avatar
notice the blackened portion of the gasket sealing area at the top left !
Old December 15th, 2012, 3:23 PM
kevinkpk's Avatar
Yea, did you notice the red rtv?
Old December 15th, 2012, 4:17 PM
old dog's Avatar
rtv and fel pro blue gasket's dont gemeraly go together except at the rubber end gasket's if you are weak enough to use them .all you need is a bead at the end's an d let it set up !
Old December 27th, 2012, 5:44 PM
panfry350's Avatar
yes X2
mattgio
Silverado & Fullsize Pick-ups
July 16th, 2015 1:33 PM
1977LT350
Corvette
June 14th, 2014 8:28 PM
GMC_C15v8
June 29th, 2011 12:39 PM
Quick Reply: 1977 chevy 350
