Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
305 to 350 interchangeable parts
Old October 8th, 2012, 9:35 AM
Frank L'Etoile Jr.'s Avatar
Exclamation 305 to 350 interchangeable parts
So over the past winter I built my first motor which was a 305 to race at the local circle track. This coming winter I want to move up a division which requires a 350. The only thing I can think of that I will need besides the block, is a set of pistons and possibly heads to comply with compression rules. Can anybody help me out with some key differences between the two motors, and maybe a list of parts that are NOT interchangeable between the two? Thanks for any tips and your time, Frank Jr.
Old October 12th, 2012, 5:07 AM
BigBoom360ci's Avatar
Does the racing class require any particular parts to match the vehicle of choice? Example, my sister ran oval and the heads and block & internals had to match the year of car she ran.
Old November 26th, 2012, 3:05 PM
zachinnis's Avatar
If I remember Right the only thing that won't swap is the crank, rod and, pistons. Bout the only difference is the cyl wall size by .260
Hope this helped
deerdan
October 10th, 2014 3:53 PM
jayco
Express & G-Series Vans
September 8th, 2012 2:39 PM
gjoec
Chevelle & El Camino
February 16th, 2012 10:08 AM
cdc9266
February 6th, 2010 5:56 AM
JohnL
Cobalt
September 2nd, 2009 8:25 AM
Quick Reply: 305 to 350 interchangeable parts
