Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
cam selection help
Old September 30th, 2015, 3:47 PM
Robert Hart's Avatar
Default cam selection help
Here is what im building. 383 stroker, scat forged steel crank 3.75 stroke, srp forged aluminum flat top pistons, 6.00 inch crower forged steel ibeam rods, gm performance aluminum fast burn heads (19300955) 4 bolt 1 piece rear main seal roller cam block 4.030 bore.
I would like to be in the 470 to 500 hp range. Intake? Holly carb size?
What size roller cam should i use to achieve this. I would like to hear the lope . Other info th350 373 posi, stall converter?
The car will be a drive to the strip and some weekend diving to shows locally
75 burner
August 18th, 2014 1:43 AM
Mattfoord
May 7th, 2014 3:04 AM
chevytruckman2004
Silverado & Fullsize Pick-ups
May 6th, 2014 10:00 AM
sojo
December 21st, 2009 4:36 PM
Quick Reply: cam selection help
